Fusion Support
Cant download Fusion 360
1 REPLY 1
lyn-maeve_franke
41 Views, 1 Reply
I uninstalled Fusion 360 on my Mac because I was having trouble downloading the Keyshot plugin. When I tried to reinstall it, it showed me that the program already exists. However, I can't find it anywhere in the Finder because I had uninstalled it. When I click on the window that lets me decide wether I want do open the "existing" Fusion, the entire window disappears, and the icon in the Dock also disappears. I have also tried restarting everything, which unfortunately did not help.
That's the report. An it says "The current version of Fusion 360 is already on this system Installed. Want to start Fusion 360?" and when I klick on Yes everything closes and on no its the same.
Help please...
1 REPLY 1
@lyn-maeve_franke
1. Go to your launchpad
2. Do you see Fusion launcher there ? If you do you should also see Fusion service utility
3. Launch the service utility and run the Repair Fusion
This should fix the problem for you.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
