Cant delete objects
Cant delete objects
charlescooke58
Cant delete objects
charlescooke58
A bit off the subject to start, when I post to forum the camera icon says to me upload screen shot, and it works, but then when I want to write something cant be found. So start again write something then upload a screenshot, WHAT am I not understanding here?
In the screenshot, the item I have clicked on when I click delete I expect it to disappear right, wrong the the whole body disappears and I am left with the item I dont want, this is a rebate for a tread to sit in of which there are 6. And again the stair former needs to sit flat on the floor and wall, so put a cp for the wall and use the floor to split body click 0n and corners and delete them. Corners wont delete or the whole thing disappears. This is all basic stuff and I shouldnt have trouble everybody with this but here I am!!Screenshot (15).png
davebYYPCU
Delete!!!!!!!!
Not the right command, it should be Remove, instead.
Delete will delete the originating body, but Remove removes the offcuts.
Undo - fixes yellow icons, BTW.
Might help....
charlescooke58
BTW, I dont see " Remove" all I see is "delete" I even searched it and got no response and I tried splitting body again and deleted the offcut a piece at a time. Maybe I should of selected body priority.
g-andresen
Please share the file  and name the relevant parts or features.
File > export > save as f3d on local drive  > attach it to the next post
günther
davebYYPCU
Select the object (Body or Component) in the browser and right click, the Item under Delete, is Remove.
Does not appear in the modify menus.
Might help....
