Cannot switch to online mode
Message 1 of 21
When I open Fusion 360 I get an error message stating "Sorry, Fusion was unable to save sufficient data for Offline mode and needs to go Online. Please make sure you have a working internet connection to continue." After clicking okay I get another pop up that says "Cannot switch to online mode either. Please check your internet connection. Application will exit now." My internet connection is working fine and I did not have this problem last week. It all started with seeing I was in offline mode due to maintenance. Coming back to it today and trying some of the solutions in the form I am not stuck and cannot even get into the program. I don't know what else to try.
I have also tried signing into my online hub through my web browser and I get an error for that also. Screenshot is attached.
Accepted solutions (3)
Replies (20)
Message 2 of 21
Phil.E
Do you happen to use more than one Autodesk ID, and logged into a different account while Fusion was offline?
One remedy is this: shut down Fusion  and delete an options file:
Delete NMachineSpecificOptions from here
%appdata%\Autodesk\Neutron Platform\Options
Then try to start and login to Fusion. Please let me know how it goes.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 3 of 21
Hi Phil,
I don't use more than 1 account. I did change my email address for my account and I don't recall if I did that with Fusion open or not.
I did what you recommended and just to confirm it was delete NMachineSpecificOptions.xml from C:\Users\user\AppData\Roaming\Autodesk\Neutron Platform\Options? Deleteing this file did not help.
Message 4 of 21
Phil.E
This is now fixed.
Please try these steps:
  1. Restart your computer
  2. Start Fusion 360
  3. Login
Best regards,
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 5 of 21
Hi Phil,
what me we the support group did worked and I was able to log in and get to my data. Thanks for  your help.
Message 6 of 21
Ok, so what is the solution here? Im having a similar problem now.
Message 7 of 21
Phil.E
Did this just begin, when was the last time you ran Fusion 360 without any issue?
Have you changed your email address in your Fusion 360 account recently, or since that time?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 8 of 21
No change in email address.
After rebooting about 12 times yesterday, logging in and out, and deleting the above mentioned file, I got it to work.
Today, back to the same problem. It tells me I'm offline, and am not connected to the internet. Meanwhile it shows that it's downloading an update. Which gets to 99% then opens a terminal window for about a half second, then fails. Now won't go to online because it says I have no connection to the internet(while I'm typing this on the internet).
Here's my diagnostic log
Message 9 of 21
Phil.E
Thanks for the streaming-update log. There are more. If you can, please open Fusion, go to Help > Support and Diagnostics > Diagnostic Log Files. This will provide a zip file for you.
Please attach the zip file, it's needed for the report I'm logging. Full logs should help show the root cause so we can work on it.
After that, please try a full uninstall/reinstall with these instructions.
Reference article.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 10 of 21
nagy.jozsef.tv2
set the correct local time.
Message 11 of 21
This was the solution.
Message 12 of 21
mariusz.materek
Not working
Message 13 of 21
Phil.E
What is not working?
Can you please tell me what problem you are seeing (w/ screenshots of any error messages) and also what you have tried to fix it?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 14 of 21
brett3G83J
Im having the very same issues, I was only using Fusion 360 less than 24 hours ago ...I only have one account and none of these fixes are helping .. Is there anyone that might be able to help me please?
Message 15 of 21
Phil.E
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 16 of 21
I am having this same issue but I don't have an Options file in the Neutron Platform file.
Message 17 of 21
Phil.E
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 18 of 21
Message 19 of 21
I get these when opening the app.
Message 20 of 21
I have followed a couple of articles telling me to change proxy settings and lan settings. I am on ethernet if that makes a difference.
