Cannot start after update
lhfFKLVG
lhfFKLVG
I was notified of an update yesterday so I installed it.  Now Fusion 360 cannot start up.  It gets the splash screen which shows a progress bar, which stops at "Loading additional modules", and a blank white window, then nothing more happens.
I have uninstalled and re-installed and it still freezes at the same point.
Are there log files that might indicate what's wrong?   Or can I delete cached files or something to get it working again?
lhfFKLVG
Running on Windows 11, AMD Ryzen 7 5800X, NVidia GeForce RTX 4070
RajkumarIlanchelian
@lhfFKLVG @Can you please do the following. ?
1. Restart machine
2. Go to add/remove programs
3. Select Fusion - modify
This will launch the Fusion service utility
4. Run the gather system info
5. This will generate two zip files
Attach them here please.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
lhfFKLVG
The Modify panel appears for a few seconds then closes, before I can do anything with it.
lhfFKLVG
Fixed it; uninstalled and deleted the .../AppData/Roaming/Autodesk directory then reinstalled it.
