Announcements
Cannot sign in Fusion360 after update...
pete_lamsa
Observer
pete_lamsa
Observer
Observer
Hello!
After update I cannot sign in with Fusion 360.
I get a window that says: "Check you browser to sign in", but my browser hasn't opened a windows to actually sign in.
Any help?
Thanks!
Pete.
RajkumarIlanchelian
@pete_lamsa Can you try a couple of things please?
1. Can you change tour default browser and then see if you can successfully launch?
2. Use this link to launch the Fusion service utility - https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-launch-the-... and then can you run the "gather system info".
This will generate two files and you can attach the diagnostics logs.zip file here.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
pete_lamsa
Observer
Observer
Thanks for the info! Suddenly it began to work yesterday without doing anything. Everything's ok now!
