Announcements
Cannot pick midpoint snaps to move a line in a sketch
daseitz5TN7J
daseitz5TN7J
In a sketch I cannot see any way to select the midpoint of the line. I searched and saw some reloaded 360 and it worked. I uninstalled and reinstalled but it was still the same didn't work.
How do I get the snaps to work. They are checked in the sketch pallet.
HughesTooling
If you want to use a point to point move you'd need to draw a point there first. Where do you want to move the line to, generally you should use constraints and dimensions to position curves. Personally never use move at all in sketches, you should be able to drag the line near to where you need it and apply a constraint\dimension.
Mark
Mark Hughes
Owner, Hughes Tooling
daseitz5TN7J
I'm trying to put the midpoint of the line at the center of the box.
HughesTooling
Click the midpoint constraint on\from the top toolbar, then select the line then the centre point\origin.
Mark
Mark Hughes
daseitz5TN7J
Simple things can be hard to find.😀
HughesTooling
@daseitz5TN7J  If you're new to Fusion and using a program with a sketch solver you might want to look at the sketch tutorials.
Mark
Mark Hughes
paulmarionpeter
Observer
Observer
How do you do this in a dwg file (not a sketch)?
