Cannot open Fusion
Cannot open Fusion
pkw6X2K4
Message 1 of 11
Cannot open Fusion
pkw6X2K4
I cannot open Fusion . I get the notification -
You can’t open the application “Autodesk Fusion 360” because it may be damaged or incomplete.
Autodesk advises me to
To avoid this issue reset / reinstall Fusion using the Service Utility.
I have not completed the reset/reinstall because there are statements about cache or file losses
that worry me.
I would be grateful for your assistance.
Peter Wigglesworth
pkw@wigglesworth-weider.ch
Replies (10)
Message 2 of 11
RajkumarIlanchelian
@pkw6X2K4 Are you on windows or Mac?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 11
pkw6X2K4
Mac - latest OS
Message 4 of 11
RajkumarIlanchelian
@pkw6X2K4 Can you go to Launch pad - Run Fusion service utility - gather system info - attach the Fusiondiagnostics.zip file that gets generated?
Autodesk Fusion
Join Fusion Insider
Message 5 of 11
pkw6X2K4
Attachments available until 13 Mar 2025
Sorry, I could not answer before.
We are in different time zones?
Zip files enclosed.
Message 6 of 11
RajkumarIlanchelian
@pkw6X2K4 I do not see any attachments. Can you please attach again?
Autodesk Fusion
Join Fusion Insider
Message 7 of 11
pkw6X2K4
Click to Download
<>MacOSDiagnosticLogs.zip
44.1 MB
Click to Download
<>FusionDiagnosticLogs.zip
523.3 MB
Message 8 of 11
RajkumarIlanchelian
@pkw6X2K4 Sorry still not seeing the attachment. In the zip file if you go into Autodesk Fusion 360 folder, you will see a unique folder name. If you go into that an under W folder, see if you have a Q folder and in that Q folder are there any files in there ?
Autodesk Fusion
Join Fusion Insider
Message 9 of 11
pkw6X2K4
Two Zip files were created.
1. MacOS Diagnostic Logs
This does not contain anything you have described.
2. Fusion Diagnostic Logs
This contains -
Neutron Platform folder > QWQKPK2F3MEN folder > Crash recovery and W. Login Folders
The last two folders do not contain anything.
OR
Neutron Platform folder > Options folder > QWQKPK2F3MEN folder > NGlobalOptions.xml
and OptionsStatus.xml
I hope this helps
Thanks pkw
Message 10 of 11
RajkumarIlanchelian
@pkw6X2K4 Thank you,. You are good to go ahead and do a repair.
1. Close Fusion (and also delete the Fusion shortcut)
2. make sure Fusion is not running in activity monitor
3. Go to launch pad - Run Fusion service utility
4. Run the repair Fusion
This should address the issue for you.
Autodesk Fusion
Join Fusion Insider
Message 11 of 11
pkw6X2K4
Helllo.
OK.
I’ll do that tomorow. Its 24.00hrs here
and I would like to be ‘awake’ when I run the
repair. I will let you know what happens.
I the meantime many thanks to you and the
Fusion Community.
pkw
