I'm having problems opening a *.f3d file that I downloaded from GrabCAD. The file in question is a model of a Hokuyo Lidar found here.
I have tried two methods to open the file in Fusion 360. The first is via File -> Open -> Open from my computer... -> select the f3d file. This gives me an error "New design cannot be created from a local file containing external references".
The second method is via the data panel, by clicking on Upload and then uploading the f3d file. The error message is "Hokuyo.f3d could not be uploaded due to access denied. This occurs when you have lost access to the project of references. Please contact the project moderator for assistance."
I thought it would be a straightforward process to open files with the native file extension (.f3d) but I guess that was a naive assumption.
