Cannot open documents, they open in browser, no editable documents
tech3QERX
tech3QERX
suddenly I can not open any documents any more. Instead the browser opens and shows the document. Also the "MyEditableDocuments" tab is empty. If I go to "RecentData" I see al the documents. Some are blue and editable (they open in the browser as described).
Fusion 360 2.0.17457 x86_64
Active Plan: Personal
Windows 10 Pro 22H2 (19045.3570)
What is going on here?
Edit: I reinstalled Fusion but the problem persists
Edit: clearing the cach does also not solve the problem
hydradude_build
Community Visitor
Community Visitor
i have this problem too pls help
it might be happening for lots of people now - probably a bug
hydradude_build
Community Visitor
Community Visitor
help this is happening to me too is there a solution
hydradude_build
Community Visitor
Community Visitor
Oh mine was just fixed check again
pawel.potyrala
Hello @hydradude_build @tech3QERX
Thank you so much for reporting the issue. While I forwarded it for the internal teams, if it still occurs, please try to use the following workaround for now:
Editable Fusion 360 documents open on web browser instead of Fusion 360 application for personal lic...
I hope it helps.
Best regards,
Paweł Potyrała
Technical Support Manager
Global Product Support
My Screencasts | Fusion 360 Webinars
patrickncowan
Now working as normal... thank you, if anyone did anything!
tech3QERX
Fixed for me too, thanks for whatever happened to fix it.
