I am 16, and have been working on trying to design an in-line piston engine for over 35 hours(not in a row xD). I have often use the feature: Construct Axis through Cylinder so I can then connect a cylinder to it in a joint, and have slide up and down with the slider joint. I have been trying to attach a cylinder to an axis with a slider joint, but it is not working. I have tried making a new axis through the engine block tube that would hold the cylinder, but it still does not work. I'm sure it's a simple solution, and I'm probably just being stupid, but I am still relatively new to CAD, so some help from anybody would be greatly appreciated! Here are some images of the problem below, and I'll see if I can post the file as well.
Here is the link to the file:https://a360.co/3rvYfLL
