Announcements
Cannot lock / define / close -- what I am doing wrong? :(
Apologies -- learning anew. So, well, what am I doing wrong -- why can't I close this ellipse? I'd like to lock it to the bigger circle. (Ultimately, I'm trying to cut a U shape out of the bigger circle. I U shaped rod will slip up into the disk.)
autode.sk/3wteXyK  (screencast)
(I'm having trouble posting this.  Why doesn't anything work?  My inserted screencast won't "stick", and the system keeps telling me there's invalid html and it has changed my post... but nothing has chang... and the system still won't accept / "stick"...)
g-andresen
@Anonymous  schrieb:
(I'm having trouble posting this.  Why doesn't anything work?  My inserted screencast won't "stick", and the system keeps telling me there's invalid html and it has changed my post... but nothing has changed and the system still won't accept / "stick"...)
This has been a problem for a long time.
Please attach the URL to your next post.
günther
Thanks - I added the URL to the screencast of my trouble: https://autode.sk/3wteXyK
g-andresen
1. delete one dimension > Screencast
2. Although the linked thread says that the problem is solved, the definitely not true. Please post the problem in the appropriate forum as well.
günther
jeff_strater
4 dimensions are needed to fully constrain an ellipse:
  1. major diameter of the ellipse
  2. minor diameter of the ellipse
  3. horizontal distance of center from a fixed point
  4. vertical distance of center from a fixed point
Jeff Strater
Engineering Director
Thank you!!!!!!!
