Announcements
Cannot fully constrain sketch
mattmyer6E696
mattmyer6E696
I am attempting to create a sketch section using a half ellipse
Once i trim away the unwanted half of the ellipse, I cannot fully constrain the sketch. Tried everything but the half ellipse stays blue (unconstrained)
(see attached screenshot)
Replies (10)
jeff_strater
can you shared this sketch here?  I know that there are issues with trimmed ellipses in general, and particularly with the fully-constrained analysis.  It may be that, or some constraint may have gotten dropped when you did the trim.  Thanks.
Jeff Strater
Engineering Director
mattmyer6E696
Hi Jeff
I couldn't resolve it so I used conic arcs with the rho parameter set to 0.414 to simulate an ellipse profile and this worked fine. I'm used to working in PTC Creo where everything has to be correctly constrained.
jeff_strater
You don't have to fully constrain sketches in Fusion.  It's a good idea, certainly, but the main reason for that is for stability under edit.  If you are reasonably convinced that the sketch is fully constrained, it just doesn't show up with black lines and and the lock icon, you can proceed.  And again, if you want to share the design, we can take a look at it.  Thanks,
Jeff Strater
TheCADWhisperer
I quite frequently have fully defined ellipse that does not show as black or lock icon.
In the Attached I attempted to reproduce the OP issue from Canvass image without even trimming the ellipse (I normally try to avoid trimming ellipse because then they almost always show blue when fully defined).
mattmyer6E696
This is an example of the type of sketch I'm trying to constrain
It's a section through a guitar neck. When you trim the ellipse, it becomes impossible to fully constrain it.
jeff_strater
thanks, we will look at that case, thanks for sharing it.  The other option is to not trim the ellipse.  Fusion is fine with untrimmed geometry - you don't need to trim it, and can select whatever profile subset you want.  Or, just don't worry about it not being fully constrained.  It's not critical in Fusion, you can still continue with your design.
Jeff Strater
jeff_strater
created bug FUS-95467 to track this issue.
Jeff Strater
rrodriguezF5XQ6
Gents,   I was able to make the arc black by right click and select fixed, turning the arc green.  Then unfixing the arc and it turned black and stayed black.
If anyone has tried this let me know if you experience the same.
Robert
rrodriguezF5XQ6
Try fixing the arc and unfixing the arc to see if it displays as fully constrained.
Regards
Robert
g-andresen
Construction lines must also be defined.
günther
