Cannot Export PDF
Cannot Export PDF
jack.scolding
Cannot Export PDF
jack.scolding
Hi, Since this morning i cannot export pdf's, DWG are fine and work as expected but when i go to export a PDF it completes but nothing shows up in the folder i chose for it to be exported to. Any ideas? I can export the pdf via the web app but this is slow as its through email.
ClintBrown3D
Hi @jack.scolding
Are you running Mac or Windows? If you're on Windows, you could try to start Fusion "As Administrator" - Right-click on the shortcut, then choose "Run as Administrator".
Let us know
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
jack.scolding
Hi, I tried this with no luck.
ClintBrown3D
Hi @jack.scolding
Alright, I've tested this on my Windows builds, and it works with no problem, so we need to try a couple of things on your end.
First thing to do is to save all of your files, close any open documents and try clearing your cache. Then restart, open Fusion and try a PDF export again.
Please let me know if this works
Clint Brown
jack.scolding
@ClintBrown3D
Just cleared the cache with no luck either. Earlier i restarted my pc and did a fresh install of fusion with the same outcome.
ClintBrown3D
Hi @jack.scolding
I would suggest a clean uninstall and re-install. The clean uninstall will completely remove Fusion, which the Windows uninstaller does not do, have a look at these instructions (download of the uninstall tool in the article).
Here's a link to download Fusion, just in case
To be safe during the installation, run the installer "As Administrator", here are a few installation tips.
Clint Brown
jack.scolding
@ClintBrown3D
This worked. Thank you for the help
