Cannot dimension correctly off of the sheet
Robert_J_Scott
Robert_J_Scott
See attached, I need to dimension (using double arrows) the centre of a radius (96.218) to the centre of a hole. The radius centre is off the sheet so I would need to use double arrows to show the part I'm referencing isn't in view.
How do we do this in fusion?
I have created a simple drawing and manually added the double arrow with "110 to ctr" to try and show what I need to do. Hopefully I'm just being stupid and haven't clicked something!
Thanks in advance
Rob.
Replies (8)
g-andresen
Please share the file to show how to create the design in draft mode.
File > export > save as f3d on local drive > attach to post
günther
jhackney1972
Take a look at the Animated GIF.  You can choose the position of the offset center and the location of the dimension.  Of course you have to select the entity being dimensioned first.
John Hackney, Retired
jhackney1972
If my Forum post solved your question, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask. If you like to read why "Accept Solutions are important, take a look at this webpage.
Robert_J_Scott
Hi John,
Thanks for your reply. If you look at the image I sent, it already has that format of dimension included........?
I want to dimension from the centre of that rad which is way off the sheet to a hole or an edge on the part. This could be done in other cad programs (no names mentioned) and the result would be a double arrow on one side of the dimension indicating the other side is not visible.
Or does my memory fail me again!???! 😒
Robert_J_Scott
Project attached.
This may not be the preferred way to dimension this but it does, I think, highlight the fact that this option is not available in fusion when it is in other CAD systems.
jhackney1972
The linear dimension you desire which creates the double arrows to indicate the dimension end is off the view is not available in Fusion at this time.
Robert_J_Scott
Ok, it's not available in fusion but, how do we do this? How do we get around it?
I cannot be the only person requiring this function so how could we get around this?
jhackney1972
One possibility is to use a Broken View.  This would possibly allow you to position both dimension points on the same view.
