I'm trying to flatten this "taco" design. I want to use the outer surface to create a profile so I can cut out the shape. This has worked for me on a similar design, so I know I'm at least going down the right direction, but I don't know where I'm going wrong here.
This design is a shape I have cut/split between two intersecting tubes, to produce this taco-shape, which I then shelled to my desired sheet metal thickness. Weirdly, I could not shell it outwards, I could only create a shell inwards. I think that is also a problem.
I've looked up various ways to select the edge/perimeter. I can select the flat faces and copy/paste them into a new sketch, but I cannot select the curved edges. This probably isn't the right way to do it though. I don't know what else to try.
Thanks!
