Announcements
Cannot Copy or Save or Save As Designs - RELATIONSHIP_INBOUND_LIMIT_EXCEEDED
Mr.Stephen-K
Mr.Stephen-K
Myself and multiple users in my company are having issues saving and copying design files.  The issues seems to have started last week after the "Service Outage" on 11/17.
When attempting to copy a design the following error is shown:
When attempting to perform a "Save As", the design shows v0 in the data panel and the progress wheel spins for a period of time until the entire design disappears from the panel.
When trying to save a change to an existing design, the status wheel will spin and the design will not fully upload to the cloud.
This issue does not seemed to be the same as other posts on this forum regarding the number of "Inbound Relationships":
https://forums.autodesk.com/t5/fusion-360-support/can-t-copy-files-quot-number-of-inbound-relationsh...
It appears this issue is effecting multiple projects that were functioning correctly prior to the "Service Outage".  These projects do contain multiple designs with a fair number of sub-assemblies and linked files, but I do not know how to determine the number of links in order to rule out the issues in the above post.
Please let me know if the limit on linked files is still a restriction or if this issue is being caused from something else related to the recent "Service Outage".
@karina.harper
sutherland-
Hi @Mr.Stephen-K
Have you tried to go through those steps?
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
Mr.Stephen-K
@sutherland- Thanks for the response.
I was able to get support with this issue from Fusion.  It was slightly more complicated but did have to do in part to the number of linked relationships.
sutherland-
Glad to see that you got it sorted out.
Do you mind sharing how did you resolve the issue so other community members can see how to solve the it?
Best regards,
Level  sutherland-
Member
