Cannot combine two bodies getting undefined error
evanmoore041
evanmoore041
I am trying to combine two bodies, body 82 and slider, but whenever I try to combine them I get an undefined error, and then when I try to do anything the bodies combine after the action, but it also combines a seperate body, R Mount.
Here is the f3d file:
TrippyLighting
evanmoore041
I am now, I have used fusion 360 for a little over a month, so I am still learning. This was my first design that was not just one part, and I know it really should be completely redone, and there is a lot I can do now with all I learned in the process of making it, but I just dont have the time.
davebYYPCU
2 ways to fix it,
Edit the Extrude feature and change to join.
or Pull the internal face to make an overlap, Combine is finicky with flush faces.
Might help....
evanmoore041
when I tried to set it to join, it just deletes the slider, and when I try to pull it, it works, but even when it is inside the slider, the parts wont join, instead it gives me Error: Combine23 Compute Failed
jeff_strater
there is something strange with the slider body.  At first I thought it was a case of not having enough overlap between the bodies, but even if I use Offset Faces on Body 82, it won't combine.  But, I did notice that if I modify the slider body by adding a small box to it, I can combine them.  We need to investigate more.
Jeff Strater
Engineering Director
davebYYPCU
Both worked for me, here, but I had the timeline rolled back to those areas being created, and no yellow icons in play,
If that helps.
