Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Fusion Support
Cannot change appearance - changed parts appear hot pink
6 REPLIES 6
daviswoody
353 Views, 6 Replies
As the title states, any appearances applied to parts change the part hot pink (no matter what appearance is applied.)
The only way to change it back it so undo the appearance application action.
Tags (2)
Labels (2)
6 REPLIES 6
g-andresen
in reply to: daviswoody
please create a sample design showing this behaviour and share it
File > save as f3d on local drive > attach to post
günther
daviswoody
in reply to: g-andresen
Thank you.
A sample design attached but when I export and load the project from the f3d file the issue resolves itself.
However, if you open the properties of the pink object you can see that a yellow appearance should be applied, but it shows as pink.
g-andresen
that´s what I see
günther
daviswoody
Thank you g. So the issue is specific to my install.
daviswoody
Any recommendations on how to fix this?
daviswoody
Solved: Somehow an appearance override was causing the issue. Right click body > Remove appearance override
I had to create a new appearance as using one of the older (possibly from a deleted part) appearances turned the part pink in error.
