Cannot chamfer edges
InDezign
Message 1 of 8
InDezign
Hi everyone,
while I can select all other edges of a body - it's not possible to chamfer one single edge.
Attached is the image and a simplified file.
Is this a known issue?
Did anyone encounter a similar issue?
Thanks and kind regards
Eric
Replies (7)
Message 2 of 8
seth.madore
It's not apparent from your image which edges on the model you are trying to chamfer, as the simplified file is fairly different from your image, thus not giving us any markers as to where is what
Seth Madore
Message 3 of 8
InDezign
Sorry, for the discrepancy in the image to the file.
Try to chamfer the outer edge (see blue line on image attached).
Message 4 of 8
jhackney1972
The outside edge is not regular or consistent within itself.  In the Screencast I square it up and it chamfers fine.  The amount I took off was just for demonstration, you can adjust the amount.  You also would be a lot better off to turn on Capture Design History (Timeline).  Model Attached.
John Hackney, Retired
Message 5 of 8
InDezign
Nice workaround, John 😉
Haven't thought of it.
Thanks a lot!
But honestly, how can an edge be "not regular or consistent within itself" while I created it in Fusion 360 and while the same edge of the body - when cutting a part of it off - can be chamfered.
These are the mysteries of Fusion 360...
Message 6 of 8
seth.madore
@jhackney1972 I suspected that might be the issue, but I'm not seeing any method of knowing that the surface is irregular. Performing a small slice and measuring across all points, it appears to be consistent...
Seth Madore
Message 7 of 8
jhackney1972
I cannot tell from your supplied model BECAUSE you do not Capture Design History.  If you did, I may be able to go back and analyst why the irregular edge occurred.
Message 8 of 8
InDezign
Unfortunately, due to confidential reasons I cannot provide the file with Design History. 😒
But anyway, many thanks again - I already did what you suggested and it worked perfect. 🤗
