I'm making a battery holder. The battery model is basically a box, which I repeat using the rectangular pattern. After I execute the pattern, I create a sketch at the bottom that I want to extrude up so that it "hugs" all the batteries. The problem is that no matter how I reference the last object in the pattern, when I change the number of items in the pattern via a parameter, the bottom sketch never updates to cover all the newly added elements in the pattern.
As you can see in the screenshot, I increased the number of items in the pattern, but the bottom sketch remained the same even though I'd projected the last item in the pattern and reference that while creating the offset box.
Can this be achieved in Fusion 360? Referencing the "last" item on a pattern, that is.
