Announcements
Can you add joint origins in an assembly?
96flintj
96flintj
Can you add joint origins in an assembly or do they need to be put in at the component level?
I thought you used to be able to..
jeff_strater
Assuming you mean:
  1. an assembly of external components
  2. the explicit Joint Origin command
then, the answer is "no" - you cannot add these at the assembly level - they have to be in the component's design.  At the moment, Joint Origins cannot even be added during Edit in Place, although I expect that to be added at some point.
Jeff Strater
Engineering Director
96flintj
Great, thank you. Looking forward to the edit in place.
