Announcements
Can't upload .f3d files to autodesk library
T3do
T3do
Hello. I decided to showcase my 3D Models and I encountered a problem. When I try to upload .f3d files to the "build" section, on my project page, I get the posted error:
Any ideas on what should I do? I tried with .ipt files and it worked, but I really want to keep .f3d format.
Thank you!
jhackney1972
Are you referring to the Autodesk Gallery Library or something else?
John Hackney, Retired
T3do
Yes, the Autodesk Gallery Library
T3do
jhackney1972
You do not have to post your message twice, once to the person you are addressing is fine.
It would seem that the F3D file extension is having an issue.  I have found that the F3Z file extension is accepted.  If you do not have an F3Z file of your model, do this.  Open your model in Fusion 360 and add an External file from your cloud database.  Use something small such as a nut or washer.  Once attached, go to your Browser and hide it.  The addition of an External file will cause Fusion 360 to automatically create an F3Z file when you Export it to your local drive.  Use the F3Z file in your submission to the Autodesk Gallery.
T3do
It works. It's more like a workaround but it works. Thank you!
jhackney1972
Not really, an F3Z file extension is one of the formats the Autodesk Gallery accepts. I will keep your name handy and take a look in a bit, as it takes awhile for the project to be official and is posted.
