08:31 AM
I downloaded the Fusion 360 Client Downloader which dowloaded after clicking update Fusion360.
When i run it, it just tells me it can't update.
The only thing it is giving me as info is: CorruptError: database disk image is malformed
After clicking the known issues and searching for the things below, the only 2 which popup in the log file are SSL and Connection.
- Errno
- SSL
- Socket
- Connection
- gaierror
- getaddrinfo
- timeout
After trying the solutions it still gives the same error.
I also tried deleting the Autodesk folder in Appdata but i still got the error.
I tried removing Fusion360 to have a clean installation, but i can't remove Fusion360 because of the same error.
I attached the log file also.
Thanks in advance!
