Hi!
I'm trying to design a very simple half tube like sheet metal part. This part needs to have cutouts at certain points. If I modify the Flat pattern, changes doesn't update the model. I've found out that this is normal behavior, and I need to unfold the bend, make changes and refold, instead of using the flat pattern to make changes. Here comes the problem, I can't pick any part of this simple half tube, because there are essentially no bends in it, this is just a half tube created as a flange from a half circle on a sketch... I would like to do something like you see on the flat, but then when I fold it back to be visible, what do you recommend? Thanks!
