Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Can't stop displaying wire frame
5 REPLIES 5
5901 Views, 5 Replies
Hey folks,
For the life of me, Fusion 360 started displaying in this weird wire frame format, picture attached.
How do I get rid of this and get it back to displaying solids? I'm new to 360, so I'm totally lost as to how I even changed this preference, but it was showing solids just yesterday...
5 REPLIES 5
jeff_strater
first thing to try:  set your Visual Style to "Shaded with visible edges only" using the settings widget at the bottom of the screen:
As you can see, there is a hotkey for this command (on Mac it is CTRL-4 through CTRL-9).  It's possible that you accidentally hit some ctrl-key combo to change the style
Jeff Strater
Engineering Director
in reply to: jeff_strater
That was it, thanks!
thats what I get for mashing keys to see what shortcuts do what. Mastercam uses a modifier/number combination to see certain views, I think I tried that here.
alisleimanchehade
I have the same issue but it’s a bit different and it sooo annoying and can’t seem to find a fix for it!
my settings are exactly as the answer provided to you but it keeps going into wireframe every time I press on the mouse wheel then it goes back to a solid! How the hell do I stop it going into wireframe each time I move and rotate my model?!?!
please anyone help me 🙏🙏🙏
then I would check the mouse settings and possibly try a different mouse.
günther
Thank for the quick reply 🙏 but it wasn’t the mouse. I went into preferences and reset all settings to default and it went back to normal guess I did something wrong inside the the settings and I have totally forgot that I even changed anything in there 😅
anyway thanks again man truly appreciate it 🙏🙏🙏
