Can't specify circle diameter while sketching
american2010
american2010
I remember been able to just grab the circle tool, start drawing a circle, then type the diameter I wanted it to be, but now, even when the tooltip says "Specify Circle Diameter" it just doesn't work.
As soon as I type a value, a lock shows up and my value is ignored.
Why this changed?
Do I need to change some setting?
g-andresen
This is a known error when using W 7.
To do instead:
1. create Element
2. create dimension in a seperate process
günther
american2010
Hope it gets fixed, even when it's a Windows 7 thing.
I know Fusion is saying there is no more support for Windows 7, but Fusion made me update so, I guess there will be Fusion in Windows 7 for a while still.
PS: In a separate process you mean by double clicking the measure after created, or adding Dimensions with the dimension tool, right?
g-andresen
this way
günther
