Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Can't specify circle diameter while sketching
3 REPLIES 3
american2010
613 Views, 3 Replies
I remember been able to just grab the circle tool, start drawing a circle, then type the diameter I wanted it to be, but now, even when the tooltip says "Specify Circle Diameter" it just doesn't work.
As soon as I type a value, a lock shows up and my value is ignored.
Why this changed?
Do I need to change some setting?
3 REPLIES 3
g-andresen
in reply to: american2010
This is a known error when using W 7.
To do instead:
1. create Element
2. create dimension in a seperate process
günther
american2010
in reply to: g-andresen
Hope it gets fixed, even when it's a Windows 7 thing.
I know Fusion is saying there is no more support for Windows 7, but Fusion made me update so, I guess there will be Fusion in Windows 7 for a while still.
PS: In a separate process you mean by double clicking the measure after created, or adding Dimensions with the dimension tool, right?
g-andresen
this way
günther
