Announcements
Can't simulate centrifugal forces anymore(?)
ngbaldus2003
ngbaldus2003
When simulating centrifugal forces, Fusion just gives a 15 pt score, not showing any bending or stress on the material, although I did the same thing as always. Even old simulations with actual results (starting around 2.X pts) had the same problem after I restarted the simulation after the problem occurred.
The screenshot I added is a propeller at 10mio deg/min (r=64mm) - in this case epoxy, but every other material gives the same result.
Did I maybe miss some update or "press the wrong button" at some point?
Thank's in advance!
wmhazzard
I did a quick test and it does seem that there is a problem with Fusion. Can you attach a f3d file of your model. Maybe @jeff_strater can look at it.
jeff_strater
I know exactly zero about simulation, but I do know people who know more than that, if you can share the model.
Jeff Strater
Engineering Director
