I don't know how this bug has seem to persist for so long. I am seeing so many threads about this same problem and none of the solution work for me. My time is set to automatic, I have deleted the Neutron.xml file and Login.xml file.
I downloaded Fusion 360 today and it started the first time correctly then when I tried to close it and open it back up again, it failed to login in. Understanding that software sometime have faults, I uninstalled the thing and reinstalled it back again - and every time it downloads the whole thing through the client. Please note that. So, even after reinstalling it showed me the same error, and then I found that fusion_remove.zip which can be used to remove Fusion, and this time reinstalling worked! ONLY to give me the same error again when I tried to start up the application second time. I have already tried to install it more than three time - and it downloads the data every time! Please have a working solution? I was testing the software so I can recommend it for a newcomer but this will just frustrate him as it does me.
