Fusion Support
Can't select hole for a hole callout in drawing
2 REPLIES 2
tomae
81 Views, 2 Replies
Trying to create a hole note for hole in a drawing.  I select the hole note feature but the hole in my drawing is not selectable.  I can select the hole for a the Center Mark feature no problem, but no go for hole note.  Is this a bug?
-Tom
2 REPLIES 2
jhackney1972
in reply to: tomae
The hole, in the model, had to be created using the hole command.  Extrude holes will not work with the Hole Note command in the drawing.  Also if a hole is projected through a curved surface, the hole command will have a hard time since the "hole" it sees is an "ellipse" .
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
tomae
in reply to: jhackney1972
Ahh, didn't realize extruded holes didn't work...
-Tom
