I have a simple body on which I want to do a circular pattern on the protruding element. I'm reasonably sure that Fusion 360 considers this element a feature, because when I set my selection filter to 'features' only, it lets me select it no problem.
When I go into a circular pattern and set the Pattern Type to Features, though, I can't select the element. In fact, I can't select anything at all. It does let me select the axis I want, and I'm able to select the entire body when I set Pattern Type to Body. I have checked, and everything is a single contiguous body, and the entire body is solid geometry. I've tried the same thing on another even simpler shape with the same result.
I've searched for similar issues but have found nothing. I did see something about a 'Find Features' tool, though. Do I need to tell Fusion 360 this is a feature somehow before being able to select it?
Am I missing something or is this a bug?
I'm on a MacBook Pro running the latest version of Fusion 360 and macOS Sierra.
David
