This is just one of those small things that I come across daily that seems like its a simple fix but is a proper pain.
When navigating files in the Data Panel on the left-hand side. If the filename is too long, it gets hidden by a ...
The only way you can see what the rest of the filename is by right-clicking and selecting 'rename' or opening in A360.
This is super frustrating when working with files that have revisions in the file name, especially if they're at the end of the filename.
If you could simply 'hover' your mouse over the filename and it appeared in full as a pop-up label (the same as when you hover over the 'File or Save icon on the top toolbar' or something similar would definitely be suffice
Also secondary to this is searching in the file search box, in the data panel. Once the search options appear, you cannot see or navigate to that location in the File directory without 'opening on the web' and manually finding the location yourself. Example of this in windows would be right-clicking on a file in a search and selecting 'open file location'.
Is anyone else having this same issues or is it just an isolated case on my behalf?
