Fusion Support
Can't scale letters
2 REPLIES 2
mauriibarbe
194 Views, 2 Replies
Can't scale letters
Hi everyone,
I'm new using this soft, and now I really don't know how to properly scale letters. I set a little box at the bottom of the circle but the text is huge, and it doesn't have any scale options. I tried with a new sketck and have the same problem. I could create the text in Paint and import it, but c'mon it's so frustrating.
Thanks in advance.
Tags (3)
Labels (3)
2 REPLIES 2
jhackney1972
in reply to: mauriibarbe
The Height is used to Scale your text.  If that is not enough, after the text is created, explode it, and then use the Sketch Scale command on it.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Can you please explain to me how you handle the Skatch Scale? What is meant by "explode it"?
Here is the link to my post: https://forums.autodesk.com/t5/fusion-360-support/scale-text/m-p/12350400
Thanks in advance
