Can't run; can't uninstall; can't install.
I've had Fusion 360 for almost two years (startup license). Today, it would not load. It hung at the splash screen. I rebooted, but that didn't help. I tried to uninstall, but got a "script error" popup dialog and the uninstall would not proceed.
I then found an Autodesk Fusion 360 uninstall tool and used it. That uninstalled the program. I then downloaded the Fusion 360 installer, but it would not install because, once again, I got a "script error" popup dialog.
I can't complain, I guess, because I have a free license, but I have put in hundreds of hours learning this program and designing all manner of replacement parts. All that training is down the drain.
Up until now I was recommending this software to everyone, but if Autodesk insists on doing updates behind my back and not letting me choose if and when to update, then I can no longer recommend the program. If I had been doing this work against a deadline, I would be totally and completely hosed.
My computer is configured so that NO PROGRAMS are allowed to update automatically in the background, including Windows. Therefore, I am 100% certain that no other program or change caused this problem.
If there is a solution, I will try it, but the support team needs to talk to the marketing department and the design team to make sure this sort of thing doesn't impact your paying customers.
