Announcements
Can't open fusion 360 on Macbook on Big Sur update
erenoku
erenoku
Today when I opened Fusion 360 a dialog opened stating that I need to update my OS version to continue using it. Fusion 360 was supposed to support Big Sur till March 2024 and it would still work but not just after the fact that. That's why I think there is a problem. What should I do?
RajkumarIlanchelian
@erenoku Let me check into this quickly on our side.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
RajkumarIlanchelian
Can you confirm if you are on Big Sur 11.7 at least? If not can you update to 11.7?
Autodesk Fusion
Join Fusion Insider
erenoku
I was on Big Sur 11.1. But my laptop is currently updating to macOS Monterey. Hopefully it will resolve the issue. Thank you for the reply.
RajkumarIlanchelian
@erenoku That should certainly take care of the issue. Please let us know if otherwise.
Autodesk Fusion
Join Fusion Insider
