Announcements
Can't open file saved on a different computer
rob23S842W
rob23S842W
I am trying to remedy a problem where a file recently saved on a different PC will not open on another. The error says
Product update required
Fusion can't open (file name) which was persisted by version 2.0.19204 with your current software version 2.0.18961.
Normally updates are automatic and no action is required by the user so I don't know how to manually update. I uninstalled then reinstalled Fusion expecting the very latest version would solve the problem. But the error message is shown above occurs even after reinstalling. It makes no sense to me.
It is only this particular file that I can't open. Earlier jobs can be opened on this particular machine.
Rob
RajkumarIlanchelian
rob23S842W
Thanks for the link. Exactly the same issue. Would you suggest I uninstall and reinstall on the computer with the blocked version or do you think you will have a new version for both machines soon?
Rob
RajkumarIlanchelian
@rob23S842W @We do have a new version now available that you can pick up on both the machines. Our apologies for the delay.
in theory if you saved in the new version you do not want to uninstall to the older version unless you have to. Due to schema mismatch you will not be able to open newer versions in older versions.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
rob23S842W
Thanks again for your reply. Also thanks to Autodesk for so quickly fixing the upgrade problem. This morning I upgraded both computers and the file can now be opened on both.
Cheers
Rob
