Can't open any projects
nolan.cheng.2025
nolan.cheng.2025
I use Fusion as a student all the time and have been for the past 4+ years. Today however I logged on for the first time in about 3 days, and I am no longer able to open any projects that I know I am a part of in the data panel tab. I can still used the open tool to open specific files and save them, but it's just annoying that I can't use the data panel gui anymore. This happens for both my personal and shared drives. Surprisingly, I have found one project that I can open, but it contains only one folder and it was shared with me at least a month ago so I don't understand why that is the only project I am able to access through the data panel. Thank you all in advance.
Nerd Nolan
Replies (11)
RajkumarIlanchelian
@nolan.cheng.2025
1. Can you please direct message me your email that you registered Fusion with?
2. Can you also check for say a personal project that you are not able to open, can you please invite the below two email to this project?
raj.kumar.ilanchelian@autodesk.com
geethapriya.shetty@autodesk.com
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
amol.tulaskar
Are you able to open file through File->Open dialogue?
nolan.cheng.2025
Yes, I am able to do that. It's just that not being able to use the data panel to navigate my designs is annoying. Thank you for your response.
Nerd Nolan
nolan.cheng.2025
Sorry, just so that I know in advance, what will you try to do?
Nerd Nolan
RajkumarIlanchelian
@nolan.cheng.2025
1. Can you confirm on which version of Fusion you are on?
2. The reason we are asking for the invite is to see if on our end we can use the data panel to open the projects and if so that could give us directions on how to address this for you.
Autodesk Fusion
Join Fusion Insider
nolan.cheng.2025
Sure! The version of Fusion that I am using is shown below in the photo. And I have just invited you to a project from a while ago which is one that I cannot open. Just for a bit more context to make sure I am not mistaken in my terminology, but I also attached a screenshot of what I am specifically double clicking and cannot open. Interestingly however, I am able to open the fasteners project. Thank you for your support 😄
Nerd Nolan
RajkumarIlanchelian
@nolan.cheng.2025 Thank you for the invite. While we continue to look at the issue the version you are on is not the latest. Can you go into Help- check for update?
if that does not show an update , go to Help - support and diagnostics - Fusion service utility and do a repair. This should take you to the newest version 2.0.18460.
Autodesk Fusion
Join Fusion Insider
nolan.cheng.2025
Oh my gosh thank you so much. I have no idea how I didn't think to just update the software, but updating it worked :)) I appreciate your timely responses, as I really needed easy access to Fusion for my school work. Thanks again, and have a great rest of your week!
Nerd Nolan
RajkumarIlanchelian
@nolan.cheng.2025 @Glad to know that updating to the latest worked for you.
Autodesk Fusion
Join Fusion Insider
amol.tulaskar
Hi Nolan,
Good to hear that after the version upgrade the issue is resolved.
Is it possible to share Fusion logs for further investigations. We wanted to check what was causing the problem with the older version?
Steps to get the log file
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-and-sh...
Thanks and Regards,
Amol
nolan.cheng.2025
Good evening! So sorry for my late response, I have been quite busy recently. I attached the zipped log files below. Thank you again for your support!
Nerd Nolan
