Can't Move / Rotate Imported SketchUp Model
I know there are several posts that are similar...but the resolution on one of them involved exporting a model from within SketchUp as a DXF/DWG.  The problem with this resolution is that I don't have SketchUp.
Does anyone know how I can import this SketchUp model and then rotate/move it w/in Fusion?
https://3dwarehouse.sketchup.com/model/eb3f81bae651883953495af8763948ad/Dewalt-DW735-thickness-plane...
ryan.bales
Autodesk Support
Autodesk Support
Hi @Anonymous,
You can if you convert the meshes to brep. It's a little tedious but it should allow them to rotate.
Ryan Bales
Fusion 360 Product Support
Thanks!  That does help.
It seems like I have imported SketchUp files before and not had to do that operation.
