Announcements
Can't manually rotate rigid group in Design
rokenbuzz
rokenbuzz
I have some components, one with a slide built-in joint and another connected to it with a revolute built-in joint. I've gotten used to clicking and moving the them manually in the Design to visualize how things move. After which I Revert Position, because I was just moving things to check my concept.
But now I've added a new component that is part of the one that rotates and connected them together with a rigid group. In the Design I can no longer click and drag them to rotate. They're stuck.
The component the group is connected to by a slide joint can still slide, but those groups components just won't rotate.
I've tried a variety of things as workarounds, such as a rigid built-in joint instead of a ridge group, or nesting the new component under the one it joins to in the Browser, but I end up with the same result.
The Motion Study animates properly, with the rigid group rotating as one unit, which implies things are correct, but in the Design I can't click and drag them like I could before.
Shouldn't this work?
davebYYPCU
Probably.  without the file, the text reads ok, but the As Built joints can be the problem, as they only work on Origins.
Might help....
rokenbuzz
I ignored my problem and moved on. Sometime along the way I noticed everything was now working as expected. I don't know why, but whatever. Could be on me as I'm just a few weeks into Fusion 360.
If I figure out what my hangup was I'll post it.
