Can't import igs file
My IGS file size is 190 MB, i can't upload or import into Fusion 360. When I select my file using New Design from file, it starts loading but not working popup appear. Is there any way to upload an igs file of 190 MB?
System has 16 GB RAM.
Please help with the issue
Replies (11)
Attached a image
60% of upload was done and not uploading further
File size can't be minimized
Anyone please give me a solution please
TheCADWhisperer
Can you zip and Attach the file here?
Can you upload it directly via a web browser to https://myhub.autodesk360.com/ rather than via Fusion?
I uploaded the file through My Hub which was successfully completed but now I getting a error "Max Attempts with no progress" when I create the design in fusion 360.
Screenshot attached
I can't upload the file so I share you the link below
https://a360.co/2NatLuu
TheCADWhisperer
You problem statement indicates importing of an IGES (*.igs) file, but the MyHub link is for a *.3dm file?
Can you post screen capture of where you got information that it was an igs file?
Sorry for the late reply. I able to import both IGS n 3dm files, I think the previous file was corrupted.
Thanks for the reply and suggestions!! @TheCADWhisperer
Hi, I have absolutely same issue with my 50mg stp file - cannot upload to new project - stuck in 60% same as your uploads. When I want open stp file thru "new design from file" fusion start to open file and after few minutes freeze and a I need to force stop program.
In two weeks ago I open same file with fusion without any issue, so can cause this last update???
TheCADWhisperer
STEP (.stp) is not IGES.
Upload to your myhub.autodesk360 and share link here for others to experiment and see if they can reproduce the behavior.
here is the file my college also try it and same issue with the file, I think something messed up with fusion during last updates...
//edit
Sorry I delete link because its not my file, if somebody from admin wanna see file and try yourself Ill send link to myhub via private message.
TheCADWhisperer
I was able to open in Autodesk Inventor Professional - but not Fusion 360.
Make sure you join/combine all your polysurface before importing into Fusion 360, otherwise import your bodies separately and then combine in fusion workspace. I figured out that my file wasn't imported because of this problem only. Once I separated my mesh bodies and then imported it is successfully done. Can you please check if this solution helps you out @Anonymous Thank you!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
