Can't get drawn blue lines to go black before rotate, then when rotated model displays black lines of the drawing.
Hi all, don't know if I'm in the right spot for this but here goes, I am drawing a parabolic curve using the conic curve command centered on the origin, then I offset if 3mm and draw a 3mm line at the vertex from one line to another, then cut away half of the two curves, at the outer part of the curves I go from the inner one (the original before the offset) and away from the origin for 8mm, then down for 3mm then back in towards the origin and to slightly overlap the outer curve (at this point the drawing fill with shaded blue then I cut the lines that overlap.
I then rotate the drawing about the origin and all looks good, except that I am now left with the outlines of the two curved parts of the drawing in black when I choose the shaded with outlines view, in just the shaded view the lines don't appear, plus I don't know what constraints I should be using between the conic curved lines and the straight lines.
Sorry for length of this post, as you will have noticed I am a complete newbie at this and any help greatly appreciated.
Thanks David
