Can't get coolant through tool to work to POST
andersEQHR7
Message 1 of 16
andersEQHR7
Why can't I get
onParameter('operation:tool_coolant', 'flood')
to be anything else than 'flood' it doesn't matter what type of coolant I set in the tool library I only get 'flood' type in the POST.
B.R.
Anders Tjernström
Anders T
Replies (15)
Message 2 of 16
boopathi.sivakumar
Hi @andersEQHR7
I could not able to replicate the issue
  if (hasParameter("operation:tool_coolant")){
    var cc = getParameter("operation:tool_coolant");
    writeComment("Coolant Codes: " + cc)
If you paste this codes in the onsection function
you will get the codes as expected
Boopathi Sivakumar
Senior Technology Consultant
Message 3 of 16
andersEQHR7
I am sorry to say that this suggestion didn't help.
I guess that I should put the code into my post-processor under "function onSection"? or should it be in the "dump.cps"?
I don't know if I was clear enough the first time?
If I in the tool setup chose "Through tool" as coolant I would like that the post-processor set M11 if I chose "Flood" I want to have M08, if I chose "Flood and through tool" I want to have M08 M11. I have found where the M-codes should be changed in my post-processor that was easy. But it doesn't matter what I chose in tool setup I always get M08  when put out post file.
B.R.
Anders Tjernström
Anders T
Message 4 of 16
boopathi.sivakumar
Hi @andersEQHR7
What post processor (.cps) you are using? is it a generic post or modified one
did you change the coolant codes in this .cps file?
var coolants = [
  {id: COOLANT_FLOOD, on: 8},
  {id: COOLANT_MIST, on:8, off:9},
  {id: COOLANT_THROUGH_TOOL, on: 88, off: 89},
  {id: COOLANT_AIR},
  {id: COOLANT_AIR_THROUGH_TOOL},
  {id: COOLANT_SUCTION},
  {id: COOLANT_FLOOD_MIST,on:88, off:89},
  {id: COOLANT_FLOOD_THROUGH_TOOL, on: [8, 88], off: [9, 89]},
  {id: COOLANT_OFF, off: 9}
If you make the coolant ids here it will definitely update. Kindly check on this if not kindly share the .cps file so that i can take a look into it
Boopathi Sivakumar
Message 5 of 16
andersEQHR7
It was a generic FANUC but it has modified to work for my machine.
I can't find your code example in it.
I have attached it as a .RAR file
All help are very much appreciated.
B.R.
Anders Tjernström
@boopathi.sivakumar
Anders T
Message 6 of 16
boopathi.sivakumar
Hi @andersEQHR7
it needs some editing in the post open the .cps file in the vs code
delete from line number 1802 to 1872
from function setCoolant(coolant{
to  currentCoolantMode = coolant;
and paste this set of codes
function getCoolantCodes(coolant) {
  var multipleCoolantBlocks = new Array(); // create a formatted array to be passed into the outputted line
  if (!coolants) {
    error(localize("Coolants have not been defined."));
  if (isProbeOperation()) { // avoid coolant output for probing
    coolant = COOLANT_OFF;
  if (coolant == currentCoolantMode) {
    return undefined; // coolant is already active
  if ((coolant != COOLANT_OFF) && (currentCoolantMode != COOLANT_OFF) && (coolantOff != undefined)) {
    if (Array.isArray(coolantOff)) {
      for (var i in coolantOff) {
        multipleCoolantBlocks.push(mFormat.format(coolantOff[i]));
    } else {
      multipleCoolantBlocks.push(mFormat.format(coolantOff));
  var m;
  var coolantCodes = {};
  for (var c in coolants) { // find required coolant codes into the coolants array
    if (coolants[c].id == coolant) {
      coolantCodes.on = coolants[c].on;
      if (coolants[c].off != undefined) {
        coolantCodes.off = coolants[c].off;
        break;
      } else {
        for (var i in coolants) {
          if (coolants[i].id == COOLANT_OFF) {
            coolantCodes.off = coolants[i].off;
            break;
  if (coolant == COOLANT_OFF) {
    m = !coolantOff ? coolantCodes.off : coolantOff; // use the default coolant off command when an 'off' value is not specified
  } else {
    coolantOff = coolantCodes.off;
    m = coolantCodes.on;
  if (!m) {
    onUnsupportedCoolant(coolant);
    m = 9;
  } else {
    if (Array.isArray(m)) {
      for (var i in m) {
        multipleCoolantBlocks.push(mFormat.format(m[i]));
    } else {
      multipleCoolantBlocks.push(mFormat.format(m));
    return multipleCoolantBlocks; // return the single formatted coolant value
  return undefined;
and go and find this line
var permittedCommentChars = " ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789.,=_-";
and paste the below codes above this line
var singleLineCoolant = false;
var coolants = [
  {id: COOLANT_AIR},
and add the on, off codes based on your requirement
Boopathi Sivakumar
Message 7 of 16
andersEQHR7
I am sorry to report that this suggestion didn't work, I got 4 fault in a long log file.
I think that I will give it up for now and change the M-code manual instead, much faster.
I also tested the newest FANUC generic file and FYI; trying to change to something else than "Flood" dosen't work in that either and another thing that doesn't work are SubPrograms in separate files. Everything stays in a very big single file instead of subprograms in separate files.
Thanks for your help,
Anders
@boopathi.sivakumar
Anders T
Message 8 of 16
andersEQHR7
I also tested the newest FANUC generic file and FYI; trying to change to something else than "Flood" doesn't work in that either and another thing that doesn't work are SubPrograms in separate files. Everything stays in a very big single file instead of subprograms in separate files.
Anders
@boopathi.sivakumar
Anders T
Message 9 of 16
boopathi.sivakumar
Hi @andersEQHR7
It is working fine at my end.. probably you might missed something while copy paste stuff
if you could attach the modified cps i can able see what you have made
also FYI the generic post looks bit different than yours.. it seems you are using heavily modified post
Boopathi Sivakumar
Message 10 of 16
andersEQHR7
Strange, here it do not work.
Attached log and cps
@boopathi.sivakumar
Anders T
Message 11 of 16
boopathi.sivakumar
@andersEQHR7
missed the setCoolant function
copy and paste this code above
function getCoolantCodes(coolant{
function setCoolant(coolant) {
  var coolantCodes = getCoolantCodes(coolant);
  if (Array.isArray(coolantCodes)) {
    if (singleLineCoolant) {
      writeBlock(coolantCodes.join(getWordSeparator()));
    } else {
      for (var c in coolantCodes) {
        writeBlock(coolantCodes[c]);
    return undefined;
  return coolantCodes;
now it should work fine
also if you want to post M11 for through coolant then
 you might need to change this to
{id: COOLANT_THROUGH_TOOL, on: 11, off: 9},
 like wise you can give the required code in the top
Boopathi Sivakumar
Message 12 of 16
andersEQHR7
No luck this time, log file attached
@boopathi.sivakumar
Anders T
Message 13 of 16
boopathi.sivakumar
did you added the function  setCoolant(coolant)
as mentioned in the previous thread ? seems like you haven't added the codes also save the post after modification if not working attach the cps file as well
Boopathi Sivakumar
Message 14 of 16
andersEQHR7
Made a mistake used wrong version of cps. 😞
Code is copied into the cps as you described and it is working except for the "Through tool" still generates M08 instead of M11 tool
Anders
@boopathi.sivakumar
Anders T
Message 15 of 16
boopathi.sivakumar
I can still see in the nc you are using flood kindly check in the operation you have used right coolant.
else share the .f3d file
File>Export>.F3d
save the file and reattach the file to this thread.
Boopathi Sivakumar
Message 16 of 16
andersEQHR7
Got it to work now, my 2:nd mistake. 😞
didn't realize that I needed to change in 2 places in Fusion 360.
Now I got M11 as it should 🙂
Thank you for all of your help.
B.R.
Anders Tjernström
Anders T
