Can't get a DXF without "open entities"
I'm making a sign that will be laser cut out of sheet metal by SendCutSend or similar service. I converted the body to sheet metal, made a flat pattern, and saved the flat pattern to a DXF. However, SendCutSend always kicks it back as having "open entities." I ended up manually tracing the contours of some of the problem areas, and got them to close on the DXF, but there always seems to be an issue. I don't know what I'm doing wrong! The sign is a simple flat body. I also tried making a sketch and saving the sketch as a DXF, but I get the same results.
I've attached the file and an image.
Thanks!
