Announcements
Can't extrude
gillesht
Can't extrude
gillesht
Im trying to estrude using sketch Esquisse2. Can't select. Is there a tool I could use to check the integrity of my contour? I'm joining an .f3d file so somebody can take a look at my sketch.
Best regards.
jhackney1972
You have some open points in your sketch but the main reason is that all the sketch is not on the same sketch plane.  The video will show you how to fix it.  Model is attached is you need it.
John Hackney, Retired
