I painstakingly designed this to duplicate an existing plastic clip for my car. When I try and extrude it or just select the plane, it won't select. What could be wrong and how can I correct it?
I did remove all of the constraints as I went. Is that somehow the issue? I thought fusion didn't need the constraints to work.
Any help is appreciated. Thank you in advance.
Edit: actually, I may know why it is not closed. At times, I would drag and drop points of the outline onto other points to get the shape I wanted. So how do I tell fusion those points are coincident. Maybe add coincident constraints?
