Fusion Support
Can't Extend PCD/Center Mark Pattern Lines in all 4 directions (just 2)
3 REPLIES 3
craigFAE4Q
271 Views, 3 Replies
I recently discovered the Center Mark Pattern tools autocomplete. It is a real time saver. It recognizes straight patterns which is a real help on sheet metal faceplates (think knob and switch cutouts). But if I want to drag and extend the centermarks, I can only do it in 2 directions, not all 4 like I can if I manually place center marks. Am I missing a magical key combination or something else?
3 REPLIES 3
jhackney1972
in reply to: craigFAE4Q
No, you are not missing anything.  This has been true of center marks created using the Automatic Pattern tool for a long time.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
craigFAE4Q
Rats. Is there something like the old Idea Station to suggest bugs and fixes?
jhackney1972
The Fusion 360 Idea Station was taken down over a year ago.  The best thing you can do is add a new Forum post with a title something like [Feature Improvement or Feature Request] and add your "very descriptive title".  Autodesk says it reads all these post but who knows.  Make sure you are very clear what you want changed.
Good Luck!
John Hackney
Retired
