Can't export to 3D printer
I have been trying to export an STL of an object I have designed in Fusion 360 V 2.0.8407 . However when I try the 3D print option, I get 3D print window but nothing happens when I click "Ok". This is regardless of whether "Send to 3D Print Utility" is selected or not.
TheCADWhisperer
Can you attach the original *.f3d file here for diagnosis?
File>Export as *.f3d and Attach the file here.
I've attached the file I was working on when I noticed the issue but it seems to be an issue with the application itself. The same happens when I try exporting any of my files. Also once I've tried to do an export, clicking on the 3D print option after that doesn't even open the 3D print window.
TheCADWhisperer
What software are you using with your printer?
Can you right click on the body and save directly to stl file and then use that stl file to generate your printer paths?
That brings up the same window as the "3D Print" option and behaves in exactly the same way.
