Can't export STL file
joris.ligthart
joris.ligthart
Am I the only one with this problem?
When I export a STL file, the job status bar doens't move and remains at 0%. When I force a shut down and reopen fusion and try again it does export the STL file in a matter of seconds. Has anybody experienced this?
Things I tried/did:
- I save the file before trying to export the STL file (I know the job status can only process one job at a time).
- I cleared the cache.
- I reinstalled fusion 360.
- I checked my internet connection and checked if fusion is in online mode.
g-andresen
try:
export via Browser > Body > rightclick > save as mesh
instead of
File > export
günther
joris.ligthart
Hi Günther,
Thnx for the fast reply. Save as mesh did the trick. I m still wondering why the 'export function' doens't work (but does work after a forced shutdown).
But I'm happy that it works again. Again, many thnx
Joris
starmada
Community Visitor
Community Visitor
I had same problem, and same solution worked. But still don't know what's the problem. Maybe bug?
Daniel2052VYHY
Community Visitor
Community Visitor
Das geht nur, wenn man eine STL Datei erstellen möchte. Ich habe nun das Problem eine DXF Datei zu benötigen. Weis jemand ob es schon eine Lösung dafür gibt? Oder hat jemand Kontakt zu einem Supportler?
