Can't export from TinkerCad to Fusion 360
bmonpays
bmonpays
I'm try to export 3D objects from TinkerCad to Fusion 360 and it doesn't work. It says that I have to be part of a team, which I am. When I start the exporting process, my team doesn't show up in the list. Thanks for your help!
gmelantoni
Hi, there is a chance that you are using Tinkercad with an account made via social sign in (like signing in via Google), and that your Fusion account is on same email but signing via Autodesk. If that's the case, and I'm assuming you want to save to Fusion Team because you use Fusion on a Chromebook, you will need to start signing in to Tinkercad using the same method you use to sign in to Fusion.
Guillermo Melantoni
Senior Product Line Manager
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
bmonpays
Thank you very much for your answer! You are right, I am signing in to
TinkerCad using Google. I tried signing in the same way I'm doing it for
Fusion 360 and it seems to work. However it looks like it created a new
account because I can't see my classes and designs anymore. Any chances I
can merge the accounts or transfer the designs and classes?
Thank you very much! Have a great day!
nicoli_silvia
Did you solve the merging?
bmonpays
Yes. I was using a Google account for the sign in on TinkerCad. The email address was different on Fusion.
