Announcements
Can't Delete components and main asssemble including components with derives.
DDP_
DDP_
I created main assemble and inserted 2 components in this assemble.
Then I edited components in contecst in main assemble from components parameters (I changed boundings, it's work fine).
And then I used "derive" feature for the boulean cut body from second component to first component.
I saved components, apdeted changes in main assemble - it's worked fine. But now I can't delete main assemble and components.
Can't Delete componens MAIN asssemble and including components with derives.
I tried in different sequences, but I can’t delete the test assembly with the components separately, and also can’t delete everything at once.
Break the link does not help, because previous versions of the files contain links, also I can not delete versions of files with links to remove the dependency of components and assemblies for deletion.
How can I remove the assembly and components from the main project? Is there any idea?
bharamk
Dear @DDP_
Could you please record video of your workflow using screencast?  I am not clear with steps what are you trying to do.
Thanks & Regards,
Ketan Bharamgunde
Autodesk, Inc.
www.autodesk.com
Thanks & Regards,
Ketan Bharamgunde
Sr.SW Eng.Test
Autodesk, Inc.
